Open house
Hurco®'s annual end-of-year open house exhibition is at our High Wycombe showroom: new CNC machines under power and cutting metal, and many of our main suppliers in one place.
As many as 19 specialist companies will have their own small stand, covering tooling, workholding, CADCAM, metrology, automation, mist extraction, rotary tables, barfeeds, angle heads, probing and machine tool finance. Existing Hurco users and new customers can talk through ancillary equipment in a relaxed, well-informed setting.
Taking centre stage this year is Hurco's machine finance option, Peace of Mind Finance, built for today's challenging conditions: for shops with a full order book now but an uncertain view of the future. A new Hurco machine can be leased for 36 months, with the option to return it after 18 months. Keep it for the full 36 months and, if the work keeps coming in, 80% of the payments count towards buying the machine.
Advisors from IEF, part of Compass Finance, will be on site to discuss all hire purchase and lease options. An operating lease can also be shown as an overhead cost, so there is no need to raise a capital purchase.
The ProCobot range for component loading will be on show: a ProFeeder-X with 10 drawers loading a VMX30UDi, and a ProFeeder Tray loading and stacking finished parts from a VM20i 3-axis machining centre. This plug-and-play loading system suits small to medium batches. A simple app on the Hurco WinMax control screen needs only a few details to set up a job, with almost no programming, and the ProCobot and the machine tool are supported by the same company.
The Kawasaki PC25 industrial robot system, first launched at MACH 2026, will be loading both vices and pallets with a variety of one-off parts on a VMX42SRTi 5-axis machine. The same Hurco Job Automation software runs both the Kawasaki and the ProCobot options, so learning and support stay simple, with no robot programming.
Completing the 5-axis line-up is a VMX30Di with a 15,000 rpm direct-drive spindle and a Kitagawa TT200 rotary-tilt table: a flexible, bolt-on route to simultaneous 5-axis machining.
Four 3-axis CNC machining centres will be powered up and making parts, from the compact, versatile VM10i to the VMX42Di with a 15,000 rpm 40-taper spindle, a 40-station tool changer and X, Y, Z travels of 1,067 x 660 x 610 mm.
Turning is represented by the TMX8MYi driven-tool lathe with Y-axis and the TM6i 2-axis lathe. Every Hurco CNC turning centre has simple conversational programming on the Max 5 control, so one-offs and small batches are quick to complete.
This year two recent used machines share the demonstration area normally kept for new ones, a reflection of the quality of current stock: a 4-axis VM20i (2024) with a Hurco H200 table, and a VMX50Di (2022) with a 15,000 rpm direct-drive spindle and a 40-station tool changer. More used and refurbished machines can be seen in the main Hurco operations warehouse, through a doorway from the showroom.
Subject to prior sale, 10 recent previously owned machines are listed on our Used Machines page, which is updated regularly.
